MikeKC130J
- Dec 27, 2011
- 342
I'm wanting to build a 351w efi and want to run 33-35 in tires what automatic transmission and gears should I run, I would like to have overdrive so I'm not running 3500 Rpms down the road.
I'm running the 4R with 5.13s. Had 4.56 but had to regear...
Mostly back roads and highway, will to mild off roading, od is a want/ nice to have for me. I’ll probably stick to 33’s also have a Dana 20. The motor will be built stockish if it’s not too much more may stroke it not sure how all that will work with Efi. I’ll have to do some research as I’m not familiar with efi at all.What gear ratio and tire size are you running now Mike?
I think the overdrive autos are the best choice too, but just for comparison's (or argument's!) sake, with stock 3.50 gears, a non-overdrive C4 trans and a 33.5" tire (a typical 35) your engine would be turning over at a leisurely 2300-2400 rpm.
It would be "a tad sluggish" off the line to say the least. Not a good combo, but I was using it to compare the highway rpm level.
With 4.11's (also a stock ratio) you would run at about 2700-2800 rpm. Probably a bit high for an EFI'd 351, but not over-revving by any stretch and would be a lot more peppy off the line.
But both are compromises. With the 4R70W trans, you have a lower first gear, a tighter torque converter, and an overdrive to help out.
With the same 4.11 gear, it puts you at about 1800-1900rpm at 65mph.
But as always, we need more info. Because it all comes down to what you want in the way of performance with your Bronco. And are you going to be running 35's for sure? Or more likely leaning towards the smaller 33's instead?
And what will your engine be built like? You said EFI, but what kind of cam? A hot rodded motor, or a stock, to stock-ish version? How is the Bronco going to be set up?
Stockish and light, or fully outfitted with all the coolest (and heaviest) off-road gear?
And lastly, but not leastly, how will you drive it and in what conditions?
We really need to know all that before we can narrow down the ratio you'd be happiest with. Otherwise you're going to get the range you already have. From 4.11 to 5.13.
And none of those recommendations are out of line either. All fall within the sweet spot for certain uses. The overdrive auto gives you that much leeway, but narrows considerably based on exactly what you expect and want.
Why did you have to re gear?
Another good aspect of the 4R70w transmission that most of the time is not discussed, is that it's got a nicer way with compression braking than the other transmissions I've used.
Now, some of that could be overall differential gearing as well, with mushier tall gears having less perceptible compression braking, but the one I'm using sure does feel nice and solid. The lower the gear ratios in the diffs are though, the better any setup is with regard to compression braking.
How are the highway rules in TX? Just remember that 2800 (is that the boat and trailer together?), while not that much by today's standards, is WAY above the stated GVWR and two-rating of an Early Bronco.
It's not that you can't tow with it. You just can't do it legally in some states. The most important aspect from our standpoint (Bronco users that is) are the brakes. They were barely adequate for stock, much less lifted with larger tires AND towing a load.
So make sure that your brakes are top-notch and then some, before you go towing even that light of a load.
I'm guessing that boat probably tows like it's not even there behind most vehicles. Not gonna' be the same behind a Bronco. Just something to be mindful of.
Good point I'll just stick to towing with my pickup. I sure I won't be legal towing on the Texas roads.
Thanks for the info.
Mike
