I was under the impression that the rear driveshaft should be as parallel to the axel pinion as possible within 5 degrees anyway and most of the angle would be in the double carden(sp?) joint at the transfer case. I would think that setting a drive shaft up like a "Z", would lead to a harmonic vibration problem. The front drive shaft is normally not engaged at high speeds, so it is not as important to have that shaft to axel pinion within 5 degrees, but in a perfect world it would be. I have never heard of making the angles equal, as this would add more bind to the overall shaft. The other issue is the double carden(sp?) joint should be better to handle an angle at high speed than a single U-joint, so why would you run the same angle at both? They make degreed shims to point the pinion up to reduce drive shaft angle. Your way of thinking would increase both angles. I am not an expert, but just trying to think my way through this logically. (That has gotten me into trouble before).
In fact I am installing shims tonight on the rear axel pads to make the rear drive shaft and axel pinion more parallel. My pinion needs to come up about 6 degrees to bring it within 2 or 3 degrees of parallel with the drive shaft.
Chris B.
