Texanferever
- Jul 27, 2010
- 144
That was 2 degrees down from horizontal! not a good situation. I tore everything apart last night and did confirm the 6.25 c bushings. So, if I install the new 2 degree bushings that should be here tomorrow, that should raise the pinion to 2 degrees above horizontal, and the caster to a 6.
Then I was thinking if I were to install the 2 degree bushings upside down the pinion angle should change to 6 degrees above horizontal and the caster should be at 2. Im not sure how it would ride with 2 degrees of caster running a ram assist setup. I also don't know if the 10 degrees of caster ever actually returned to center without me making it return to center.
Any ides on that one?
FYI, I don't want to cut the outer "C's" ecpecially right now since I am going out of town this weekend and want to take the bronco wheeling.
