kburandt
I recently acquired an unfinished project and need help help figuring out the drivetrain and getting the right crossmember. I originally understood it to be 4R70W and advance adapter to the Dana 20. However it's not AA's 50-2704E : Ford AODE & 4R70W adapter kit. The casting is RF-F67P-7A040-AA which is a BW1356 transfer case adapter so I'm not sure about the black adapter connecting it to the Dana 20.
The PO fabricated a crossmember (right photo, bottom) which works to hold the transmission (note the offset holes drilled in the crossmember support on left photo) but interferes with the double cardan joint on the front driveshaft.
1) What setup is this and should it work?
2) Can anyone point me to examples of a well-fabricated crossmember? I can rework the existing one but don't want to reinvent things.
Thanks!
Thanks!
