Drop spindle Dana 60 build
Qumanchew
Kutztown PA
I thought some of you might get a kick out of this pile of parts I cobbled together. I'm calling it a " drop spindle 60" because my original design was using spindles instead of unit bearings, but also because I don't know what else to call it.
So a little back story/ motivation for building this. This Bronco is my wife's, so first and foremost it's a driver, so that is what it has to do best. It only has 32s, and isn't getting anything bigger. It's honestly the best handling early bronco we've had...buuut, I've been getting the itch to wheel it more, and obviously the diff clearance on 32s is not much fun. I've been building this in my head for a while. I decide it would be a good winter time project and started putting this together last November. The wheel centerline is 3.5" below the pumpkin centerline giving it that much more diff clearance.
I have no idea in the long run if this is going to be a win or fail, but it's been a fun project regardless.
phred
Earth
That looks a little like the axle Todd Foss built for his truck although his is only “kinked” on the long side if I recall correctly. More details please I very intrigued on how this is put together.
Yeller
Rogers County Oklahoma
Been a few done. The ones I’ve been around in the rest had a hard time surviving due to the weird torque loads on the housing. With modest tire size and not trying to hang with comp buggies I think it will be great or at least a great experiment. I like things tried that are different, so I’m watching.
Qumanchew
Qumanchew
Kutztown PA
We're on the same page. I'm definitely low on HP and minimal gear reduction with a np205 and 3.50 gears.
Qumanchew
Qumanchew
Kutztown PA
I'll start at the diff and work out. I shaved the housing and added a fill plug to the top as well as a breather and fitting for an arb. I scored the arb on eBay as an open box for $900. It's a 35 splined unit. I'm using the seals-it axle seals just outside of the bearings. Coming out of that are short side, 35 splined Dana 60 front shafts. I made some aluminum spacers to hold the shaft centered in the tube. Basically, two half moon shaped pucks that went around the shaft before it was slid into the tube.
Qumanchew
Qumanchew
Kutztown PA
One big goal from the beginning was to use all off the shelf parts for the wear/ breakable parts and I was able to accomplish that.
Attached to the inner axle shaft is a 1480 series driveshaft yoke to a 1.5'' splined shaft with a carrier bearing, to a 1480 series slip yoke. The carrier bearing on the splined shaft is what would be on a truck with a 2 piece driveshaft. I had to make the pillow block to hold that bearing. I'm calling these parts the intermediate shaft, basically just a short driveshaft.
I debated a long time on how much drop to build in and u-joint angle was a big concern. I settled on 3.5". That equated to 21 degrees of angle at the joints. There wasn't any science involved in that decision, it just seemed exceptable.
