I have thought about doing that myself, since I am about the same height as you.. Pull up to a stop light, bend way forward and bend the neck to see... Its no fun.
It depends on where you are dropping the pans at in my opinion. If you do the entire thing, there are a couple of minor issues to deal with. First, if you have an Aux fuel tank, its probably going to have to be changed.
Second, if you drop the floor pan under the pedals, its going to create a little bit of space between the pedals and the floor. It may not be enough to even notices, but then again, it might be.. and that could potentially be a safety hazard if you go to slam the brakes and miss, or worse yet, get your foot stuck.
If you just drop the back part where the seat rests (if that makes sense?) then it seems to me you might get the "go-cart sensation," of having your pedals almost directly out in front of you flat.
Other then that, I really don't see any major problems with it, and it sounds like a hell of an idea. Take lots of pictures.. us tall guys might want to know how to do it in the future! ;D
