Drum to disc spindle question
1969sport
So Cal
Hey there,
I recently bought a D30 with a disc brake kit on it. I have a D44 with drums that I’m swapping the Discs to and noticed that the spindles that came off of the D44(drums) have a deeper knuckle seat than the disc spindles. Its approx. 1/4 inch difference but that 1/4 inch increases the distance between the slinger and the hub and between the inner slinger and axle tube. Is this a problem or normal for these disc kits?
70broncobeast
I don’t know anything about Dana 30s but I’m fairly certain that the caliper bracket gets sandwiched in between the spindle and the knuckle of the 44. That’s why the boss is longer. It will still seat into the knuckle after the caliper bracket.
broncnaz
The disc brake setup swaps between d30 and D44 no problem. If you have the drum brake D44 knuckles on the 44. check the vendor sites all the gm style brake swaps interchange
Just to be sure that's a normal disc brake spindle you could clean off the edge of the flange and look for a Dana/Spicer part number. Then compare to what's in use with the kits.
Doesn't hurt to know for sure.
1969sport
1969sport
So Cal
Thanks for the info. My biggest concern was the larger gap that would exist between the slingers and the spindle and axle tube but as I understand it, these are just to keep the bigger debris away from the seals and aren’t on all d44’s anyway.
Ill definitely look for a Spicer/Dana # and compare.
I'm more concerned with less engagement strength from the shorter spindle register than the distance of the slinger and seals.
But speaking of that, is there a deeper recess in the deeper spindle that might keep the relationship of the seals and slinger similar to the original?
If it's a normal thing, then I'm not concerned because there are literally hundreds of thousands, if not millions of vehicles driving around on this combination of parts.
But I'm still glad you brought it up so we can at least check to see if yours is an oddity for some reason.
Hoping someone has measured theirs and compared so we can see if it's just the way it is.
1969sport
1969sport
So Cal
Good call Paul. There is a deeper recess in the drum spindle, and overall, the distance between the end of the spindle and the inside of the inner bearing is the same = 5 7/8”
Now the I have the caliber mount off and can set them next to each other, the only difference I see is where the spindle mounts to the knuckle, all other measurements line up. Seems the reason for the shorter spindle register is to make room for the caliper mount.
On the pics, the drum spindle is on the left, disc on the right.
