Drum Vs Disk... Give me a brake!
thesnake
I had the brakes redone all the way around on my 73 sport and even tho' they were a 100% better, they still sucked. Disc brakes are the ticket.
john
B
bluefx4
Raleigh, NC
Thanks for the input guys. I think I will get my drums back in to good shape and then make plans for a conversion.... and save up some $
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
jerry said:
Or, how about a vacuum resevoir of sorts, in line between the booster and the carb / manifold? It would have a check valve in it to retain vacuum if the engine died...
Just a thought,
Jerry
A reservoir would certainly be helpful, providing for a few more good pumps of the pedal. But for me, it seems that the only times I ever kill the motor is when I'm in some godawful precarious position, and I would like to be sure my brakes are 100% functional at those time. The few pumps gained from the vac res might be all I need, but I'd rather have more.
Rustytruck
I hope you and your truck make it to the conversion point. What ever you do if you have to replace the front drums really consider doing the front disks now.
mtkawboy
Billings Mt
Everything new from front to rear on my drum brakes and they are still scary after driving with discs. Plan ahead is the key, while driving and putting new brakes on. In other words put the front discs on
