It is constantly returning fuel any time the pressure is greater than what the fuel regulator accepts. (Basically all of the time) If you try to run it into one tank then you will quickly fill that tank and empty the other one.Nobody said:Thanks! Those electric switch valves sound like the ticket.
Curious, how much fuel gets returned?
I seriously doubt that you drive yours up any steeper hills than I do mine. On more than one occasion I have had the front end past the breakover point with the front tires in the air where I had to stop and use a winch just to get up the side. Purred like a kitten every time. Granted I had at least a quarter tank of gas every time so I don't know if that would have been the same case when the tank was really low.edge4 said:You can find my tech article on installing twin switched tanks, accumulator, and EFI in the CB Bronco Tech section. I respectfully disagree with saddle up on the sucker pump and accumulator. I pulled air a couple of times into my fuel rail on steep climbs without them. Last place you want this to happen.
Edge
The stock truck valves or at least the ones on late 80's trucks require a pusher pump on each tank to work. I.E. They are pressure activated depending upon which tank is pushing fuel to them. I have one from an 88 in the garage that I was going to use (It cost me $5 less than yours did) but I opted not to even though I already had the extra pumps because it would complicate a system that already was working very well.casadejohnson said:I just went to the junk yard today and got a stock ford truck/van valve for Fuel injected vehicles with dual tanks. Now I just need to figure out the wires and put it in. I'll let you know how it works out. The price was right, I only paid $5 for the valve with fuel line to the fuel rail.
SaddleUp said:The stock truck valves or at least the ones on late 80's trucks require a pusher pump on each tank to work. I.E. They are pressure activated depending upon which tank is pushing fuel to them. I have one from an 88 in the garage that I was going to use (It cost me $5 less than yours did) but I opted not to even though I already had the extra pumps because it would complicate a system that already was working very well.
Since I don't recall having any wires attached to mine and it is currently buried I'm going to say casadejohnson probably has one of the pollak valves. Especially if it resembles the ones on the Pollak page. The one I have from the 88 doesn't come close to being the same. It is much larger. If it was handy I would take a pic of both side by side for comparison. (I know right were the Pollak one is since it was only a month or so ago that I took it out) I wonder how many years each side of 86 they used it? That would be the ticket for those doing it on a budget.lars said:Not necessarily, though Ford did use a pressure activated setup in some systems. The application for my Pollak valve was an 86 F250, same as my high pressure pump. It's true that the F250 used low-pressure in-tank pumps that were switched by the valve, but they aren't necessary. The internals of the valve I have are identical to the Delco-spec valve. The only difference (which also happens to make the GM valve cheaper and more user friendly due to connector availability) is that Pollak molds the GM valve so it can use a Weatherpack connector instead of Ford's proprietary connector. I've had both types apart on my workbench. They are internally identical. If you have a Ford valve, just make sure you've got the mating connector as they are impossible to get. Here's Pollak's page with all the bits & pieces, including the GM-style valves and corresponding Weatherpack connectors: http://www2.catalognavigator.com/pollak/category/fuel-tank-selector-valves
casadejohnson said:Well I did some tests and I'm sure that my valve will work. I even figured out the wiring from the valve to the tank sending units. I just have to wire my current switch so that it can reverse the polarity to the valve. It actually works very well and I got all of the fittings that attach to it from the donor vehicle so the install should be easy.
What are you all using to attach your fuel lines to the frame? I'm moving my lines from the inside of the frame rail to the outside to keep them away from the exaughst and I'm looking for a good mounting method.
