Do the Nationals start sagging? I replaced my front springs with a pair of Cage coils Friday and I'm looking at the rear springs next. I recall you saying that the Nationals flexed better when we were at SOB but I don't want them if they are going to sag on me after a year or two. I'm also thinking about waiting to see what Jim Cole comes up with. He said they were about 8 weeks out. BTW, Is that 43 with the pin out?nvrstuk said:I've been running them for 4 years. No sag, excellent flex although not as much flex as Nationals. They will not bend past a straight line between leaf hangers.That to me is just fine since I'm still running 43" up a 30 deg ramp. I'd rather not have my springs sag in a couple years and it does help with body lean/roll. Body roll is noticeably less on a side by side (as in two Broncos side by side on top of a Subaru) comparison next to Nat. springs.
11pk Duff rear and his sits too high
For Jim I don't mind being a guinea pig to some extent. We discussed quite a bit when I was out there friday and even found out he worked in the same off road shop several years ago as I did. I think his products will be an asset to the EB community so I don't mind some trial and error if it will help support him.Unregistered said:For quite a while it seemed like all the Nat. rear springs sagged or settled. Lately they haven't had as much problem but I still hear of a few that have sagging problems-not as common a complaint. IMO I'd still be concerned if I was looking at buying them-my opinion. If you know a product has had a major problem in the past you just want to be sure it's been corrected 100% before investing time and $$. I know of one guy who has the 11pk Duff rear and his sits too high compared to mine sitting side by side with exact same springs front and rear.
Jim is sharp and I would guess his (Cage) new springs would be excellent. Course they would be brand new and you would be the guinea pig... :-(
Unpinned yes. about 6 more than pinned.
He mentioned shocks and shock hoops were something else we discussed. I won't get blocks anywhere near mine again. (I had 1" blocks on it at one time) Too big of a headache to pull the blocks back out in the campsite when the rear end starts wrapping up because they started collapsing. (Even with Duff traction bars)jpoore said:I'm in the same boat. Just put the CAGE coils in front, blocks in the back, and RS5000s.
The CAGE rears are due (I think) the end of Sept. Perhaps there will be a mass buy? Plus they are supposed to be developing shocks as well. I hate these 5000s!!!!![]()
JP
Brian (I think I got the name right) has a wristed radius arm. Pinned is with the arm pinned solid. Unpinned is with it pulled to allow the radius arm to flex more. I watched him on the ramp at SOB which was pretty impressive and then stopped by his camp site for a few minutes. It was impressive enough that I'm rethinking how I have mine set up.75 said:what does pinned or unpinned mean? thanks~bill
