dumb steering column ??
74fiberglass
Been checkin junk yards,all kind of 78-79 bronks No tilt columns unless I ain't lookin right Where is the Tilt lever at on the column? Any piks
EX-BRAVE
Hooterville
If my memory is right you pushed the turn signal lever towards the dash and the column moves up or down.I had a 79 p/u and i believe thats the method.
bigmuddy
Marthasville Missouri
EX-brave is correct about the way they work. The easiest way to tell for me at least was to look for a little notch on the dash side of the turn signal lever. If it was there I would then climb or get into the car to check it out and make sure.
Ben
EX-BRAVE
Hooterville
I once owned a 66 Ford Galaxy 500 , 2 dr. with bucket seats and the wheel did not tilt but if you pushed the gear lever past PARK the whole column would slide to the passenger side. Made getting in and out easier for large people I assume ??
