BanditBronco
- Jul 2, 2008
- 690
Working on a Bronco right now that was a frame/body swap. Basically, a rolling chassis from a "running" Bronco swapped under a Body from a different "running" Bronco. The chassis had a carbed explorer motor in it, so it has all of the explorer front dress. Engine has a Duraspark dizzy in it. I have two duraspark modules, one that was mounted on the body, and one that came in a parts box. Is it possible to run the explorer ignition coil with the duraspark system? It is still mounted on the front dress and no other coils came with the Bronco. Technically it is still a two-wire coil, but I couldn't find anyone that had done it.
Thanks, Bandit
Thanks, Bandit
