It's pretty easy relative to other things you could do. If you feel comfortable replacing your own brake shoes it's a piece of cake. Two hour tops, but should take less than an hour. You don't need to take the brake shoes completely off to get to the e-brake bar. Just take off the lower spring and brake self adjuster. You can then get to where the e-brake connects easily. I wish I had known about slipping a 12pt socket over the retainer on the old ones to get it to slip through the hole. I grabbed the prongs on the retainer with needle nose pliers and broke them off until it was able to slip out
I just did it with extended cables from WH. The only problem I had was that my original center cable has a threaded bolt on the end that hooks up and adjusts the PS and DS e-brake cables. With the new cables I was only able to turn the nut barely onto the threads of the center cable, otherwise, everything was too tight and you could not depress the e-brake pedal enough to engage. I believe they were designed this way, because they will stretch slightly over time and I will be able to turn the nut further down the threads then.
