New WH E-brake cable install help
Bundy
My new Wild Horses E-brake cables (the rear sections going to the drum) have a different style c-clip retainer as oppose to the one I that clips the ends in on the stock cable... do these replace the stock retainers or are in addition to the stock ones? I ask because there are no c-clips on the old ones, just the square style retainer.
Old style
New style or do they work along with the brake retainer clip?
Also, where does the cable disassemble inside the drum?
Bundy
Bundy
Now I'm kind of stuck as to how to remove the end going into the drum. Do I need to disassemble the whole thing? Which spring do I remove without everything coming apart?
Jeff76
Alpharetta GA
Old style
Reuse the stock U clips. If there is play behind the plate after you install the U clips, remove them, and use the new clips on the back side. Then reinstall the U clips.
Jeff76
Alpharetta GA
Take pictures first. You may not have to fully remove the brake shoes to get to the ebrake u hook where the cable connects, but then again you may have to. Remember that you have a mirror image map on the other side of the Axle. Just do one at a time, and use the other for reference if you get stuck. Not really too difficult.
garberz
Bronco Influencer
Conejo Valley, Ca.
Ryan, just use the new C-clip to secure the housing to the bracket, which ever slot is the tightest. That star collar on the backing plate is a pain to remove, have fun with that. Once you remove a few springs the whole thing starts to fall apart, so like Jeff76 said, do one side then the other, so you can see how it goes together.
Bundy
Bundy
Thanks guys.
I took apart the driver's side drum leaving the passenger side intact for reference. Jeff, Turns out you do have to remove the shoe assembly to really get to the EB connection!
Mark, you weren't kidding about the star collar being a PITA- I had to just remove the entire backing plate and work on it with pliers and a screw driver on a table to get it out!
The new c-clip design is much better so I'll see how it fits without the stock U clip... mostly because one side was missing the original and I already ordered the parts at O'reillys.
As it turns out the shoes need to be replaced and the wheel cylinders were shot so those are being replaced along with the drum hardware kit (is that just the two springs on the side?).
This all started with a leaking diff that when I was under the truck I remembered I have new WH ebrake cables and how my EB doesn't work. Then I found a barely leaking axle seal when I pulled off the drum for the EB so now it has turned into almost a complete rebuild of the rear brakes AND dropping off the axles for new tapered bearings and seals.
Ugh, the snowball gains momentum...
