Hey there. Welcome to classic.
When you say the bow doesn’t drop like it should, do you mean that it won’t drop down and fit to the top the windshield? Or that when you want to fold the top down it won’t rotate back cleanly?
Sounds like a pretty custom cage, but if it fits around it, then it was probably built with the top in mind.
These don’t always simply fold down like a convertible top does anyway, so having to go through a few extra motions to get it to work, might not be the end of the world.
More hassle, yes. But workable.
That said, the Bestop does differ slightly in that front area and the riser and top to fit taller in the front windshield area. But I can’t say that the bow would fit any better.
If you have pictures that you could put in your garage or a gallery, or email to one of us with the contributor status so we can post them up, that might tell the tale.
Or you can become a contributor for $12 a year and post them up directly to your thread. Might be a lot to swallow when you have just joined a group, but ease of posting images helps a lot when you’re trying to diagnose things.
Have you been driving the bronco long? Or is it brand new to you?
Good luck with the solution. If you end up needing a longer discussion on the top issue, definitely start your own thread with that in the title.
But no worries. Joining in this discussion was a good way to get more eyes on it immediately.
