eating up u-joints
NC-Fordguy
Bethel/Greenville NC
Guys.....
Every 4-6 months I'm replacing the rear u-joint that bolts to the 9. The needle bearings are disenegrated. I've used spicer, napa, and brute force brands from advance and they all last about the same amount of time. Torqued to arount 15 foot lbs.
Since I've had the truck, I have swapped rear ends, rebuilt the one that is there now and replaced the rear drive shaft with a new one.
Drive-line is a c-4/dana20 on stock wheelbase with a 3.5 suspension lift.
I'm guessing this has to be a pinion issue, however speaking with bronco vendors looking for shims, I've been told that a 3.5 lift doesn't need to be shimmed.
Ideas???
NYLES
How often you grease em? and if it looks like it a shim would help shim it! a better angle sure cant hurt it!
70_Steve
Old Guy
Ideas???
My idea is to check the pinion angle yourself. Read my Pinion Angle Tech article (<< to the left<<). I had to add a 6deg shim with only a 2 1/2" lift.
NYLES
Ya know steve I might need do that myself! 2.5 lift but pretty steep lookin
surfer-b
I would say you will need shims, check the d-shaft angle realative to the output shaft on the chunk. I 'm running a 2.5" lift and had to install a 6* shim. I believe there is an article on this in the tech section under "pinion angles". 70 Steve just posted this before I finished.
NYLES
Great acticle, cept the fact you just added a ta do to my ta do list! I can tell from your pics Ill be ordering some shims. QUESTION! my rear driveshaft looks maybe a tad short....will adding new shims to change the angle help on that issue?
I know it wont change it much but doesnt need much either.
70_Steve
Old Guy
What good is a "ta do" list with out "ta do's"??!!
I suspect changing the angle will not make a noticable difference in the length of your driveshaft.
cesco
How many miles are you getting on a u-joint? are just 2 caps burning up or is all four?
oleguy74
calif city ca
depending on conditions twice a year you should check and grease those u joints.lot of guy's put to m,uch grease through zerk fittings and blow out the seal.better to pack by hand .then you can check condition at same time.just my opinion.
RajinCajun
HawleyTX, La orig.
Yup.. you will be suprised at just how little it travels. Buddy's Heep with a spring over lift and soft springs, only moved the drive shaft length about 5/8" IIRC..That was from full stuff to full droop... It wasn't much... we expected more honestly.. we even measured it twice :)
bax
Old Member
I am interested in this answer. Also if only 2 what two?
you may have a bad yoke.
Bax
csjr
Lighthouse Point, FL
My bet is it's the pinion angle. You should be 1 or 2 degrees down from the DS at ride height with a stock double cardan style DS. I would think you would feel some significant vibration with a bad pinion angle though. I did with new rear springs. I only drove it to the local 4x4 shop with the new springs installed to buy the shims. Vibes were pretty bad. Just for giggles you might check your U-bolts and spring perches as well for damage or slippage. Good luck!
NC-Fordguy
NC-Fordguy
Let's see.......
Never regreased the u-joints as after 4 or 5 months they need to be replaced(the brute force brand doesn't have a provision for a zerk nor the heavy duty napas)
All four caps have their bearings disintergrated-torqued to 15 lbs or so
I'd say I put 7-8k miles a year on the truck
perches are good. I've had the same issue with two different rear ends and driveshafts.
I have noticed a vibration, but only just recently. This coincided with installing new t-case mounts as the old ones were pretty much worn out. I can tell that the new mounts have raised things up a bit
As I stated before I asked a couple bronco vendors and was told a 3.5in suspension lift did not need shims. Looks like a second opinion was/is needed.
I'm agreeing with you all who have posted the shim suggestion as what else could it be????
NYLES
"I have noticed a vibration, but only just recently. This coincided with installing new t-case mounts as the old ones were pretty much worn out. I can tell that the new mounts have raised things up a bit"
New T case bushins.....hmm I did that too! double whammy! Steve come help on my TA do list!
hey you did put them T case bushins in right didnt you? The big fat ones go on the bottom...I know its backwards but....does funky things to your engine angle and as you said your driveshaft angle...again big on top would make that DS angle even worse!
Yall slap ya knee if ya think Im crazy!
