eating up u-joints
Socal Tom
San Diego, CA
Make sure that your slip shaft is working properly. If its not sliding, then its putting a lot of pressure on the u-joints everytime you hit a bump.
Tom
Mikey
I have a 2.5" lift and measured my pinion angle at 7.5 deg....I need to shim mine once I get it back on the road.
Broncoward
Rolesville
I have the same issue (pinion Angle) with a 2.5 lift...Why is it "they say" 90 percent of the broncos with 3.5 and lower don't need it? I challenge that statement!! I belive you can get by with out correcting pinion angle but it should be corrected!! What say you?
Mikey
I think most experts do lifts go for much more that 2.5" so really don't know. Us mellow types have to figure some of this out on our own!
22213evl
Rio Rancho N.M.
I have a 5.5 lift, and a 4 degree shimm was enough. put on one of those aa output shaft housings (1.3 longer than stock) and started eating u joints, lots of vibration when on the throttle. gonna try and put the 4s back in also an see what happens
Socal Tom
San Diego, CA
I bought the angle guage at Lowes a few weeks back. It said I was 6 degrees out, but it looked like there was a little gap at the back of the springs. So I bought a deep 3/4 inch socket for 1/2 drive and cranked on it some more. Got it down to less than 1 degree.
Tom
