Sorry about that, Paul is correct about axle lengths. The F150's I run are equal, but the EB shafts are not. That said, the .94" offset of the pinion relative to the centerline of the differential housing is true regardless of application, housing width, etc., since that's just a function of pinion axis offset relative to the carrier. But it sounds like your axle builder wants the pinion offset relative to the housing ends, A+B = Overall Width.
So with that said, I pulled the tape on the '77 EB rear end on my shop floor, and measured 24" passenger and 26.25" driver +/-1/16" from the inboard side of the outer lip of the drum backing plates to the centerline of the pinion as best I could eyeball with a tape measure. If you go by that, then the pinion is offset 1.125" towards the passenger side relative to the housing ends.
http://www.9inchfloater.com/images/dwg1_lg.gif
Schreiner will supply axle lengths to suit the housing they build, so axle lengths don't really matter at this point, just pinion offset. Sorry for my confusion above.
Tobin
