z-one311
69? What!
First of all anyone that has ever turned a wrench know that the money you put into a vehicle is never the way you figure out how much its worth. It called up keep. And if it need that much work done to it then what is it hiding underneath. Yeah i don't doubt you could drop that amount of cash for one if you are building it. The labor alone will cost you your first born. But for my money i would have a/c, and does it even have rear disc brakes?, Plus a c-4 and not any kind of 5 speed or overdrive transmission. I mean come on does it have some kind of secret happy ending item that i don't know about. And yes paint costs some cash but for what he paid he could have bought a whole new body and saved 20 grand! Who puts a spool in for that kind of money. For a 5th of the price he could have air lockers and a on-board air setup. I just don't understand. I am building a 1970 with a zf 5 speed to Dana 20 to 302 bores .30 over with a ho electronic injection. Saginaw pump with hydro boost, Front and rear disc brakes, extended radius arms, A/C that i will either convert to an air compressor or use a/c, 66 half cab Baja with roll cage. Warn 8000 pound winch that can be used on the front or rear full and half doors. 34/10.50/16 on new alloy 16 inch 5 on 5.5 dual gas tanks. Heavy duty half ton rear end with limited slip and limited slip in the front. Headers new dual 2.5 inch exhaust with over 300 hp. And hydraulic clutch with tilt steering. 3.5 inch wild horses lift and 2 inch body lift. All of that after all is said and done will be some where in the ball park of 10k for me. Then its hard to believe that what he has is had 69k worth of work done. He got raped is all i know. And the bronco looks bad ass but for what it cost i could build two just like it and better!
