Maybe not be best option, but an option:
'96 F-350 7.3L TD will get you an aluminum bodied, plastic reservoir master cylinder of either a Ø1.125" or a Ø1.25" bore depending on which application you select (DRW, etc.). Some come with the RPV fitted to the rear output port, others do not. If you order one w/o the RPV, the only source for the RPV that I have found is a junkyard. Try for one without Cruise Control so that you won't need to plug that switch port.
Based on the exceptional pedal feel in Snowball, I suggest the Ø1.25" bore.
If you want the Ø1.125" bore there is a Dodge option of the same construction that is likely a better choice. Strange Engineering sells their version of it here:
https://www.summitracing.com/parts/str-b3359ta
