Edelbrock Performer fuel filter?
jckkys
Most of us know that the AFB is not the most Ford friendly carb. We also know they work for years with little maintenance. So I'm keeping it at least for daily driving. The fuel inlet is usually on the wrong side for Fords and at the wrong end (the back). A sanitary plumbing job with an inline filter between the pump and the carb using 3/8" steel lines all the way is less prone to cause fires and is what I want. The after market has plenty of in line filters that use -6AN fittings but cars and trucks came with 3/8" steel fuel lines that are big enough. The OEM filters that use 3/8" flare fittings are often large diameter and hard find a good mounting place for. That and the way to buy them involves knowing the make, model,and year they came on. Has anyone come across a good candidate and the Fram or Puralater part number?Or the original application?
