I didn't really want tp make a new post, so I edited my old post.
I have the Advanced adaptor kit, the new trans is here. Since the bracket that comes with the Advanced Adaptors kit doesn't work with a J shifter, I picked up a T shift Dana 20 that I am rebuilding.
Here is my plan
I ordered the master rebuild kit for the T shift Dana 20, from Jeffs, and it looks like rebuilding the Transfer case will be a peice of cake. I took it apart last night, and re assembled it, just for practice. I took the spud shaft, from the AA kit to a local shop today, who removed the pressed in the new seal to the AA housing, and helped remove the snap ring from the D 20 input gear, and helped me tranfer it to the AA spud shaft.
I decided I don't really want to mess with the shift rails, and think I can live without twin sticks, so I ordered this shifter from Wild Horses, along with there output shaft.
So since I have a new(to me) transfer case, I am going to mock everything up, and assemble everything at my house. That way when I do the swap, I can remove the old trans/transfer case, and install the new setup the same way.
My questions are
The AA kit comes with a new clutch plate, but not with a throw out bearing, or the clutch bellows. I replaced the whole clutch about a year ago with a LUK clutch. Should I replace the thow out bearing, and the bellows part of the clutch with a Centerforce setup, or is it ok to use the Luk stuff along with the centerforce disk. If so does anyone have the part numbers for those two parts?
Anything else I might be forgetting????
Don
