EEC-IV computer question
Mark
Bronco Klutz
NW Indiana
I believe that any EEC-IV computer should work with Mass Air from a 89-93 Mustang regardless of engine? I'm using RJM harness.
I pulled an 8CB computer from a 2.6 Liter 1990 Mustang automatic.
Should work the same as from a 5.0 - correct?
I'm getting codes, all soft and inconsequential.
1sicbronconut
You are joking right? 1990 Ford 2.6L? no such engine. To answer your question you do need a 5.0L mass air computer to run the engine you have. I guess if you have a tweecer you could get anything to work but for most of us that's not a option.
Mark
Mark
Bronco Klutz
NW Indiana
I don't joke.
2.6, 2.9, 2.3, 2.1, 2.2, - if they aren't 5.0, then they're the same to me. Actually it was a 2.3. I don't want to know every engine Ford made.
Must be from a 5.0 huh, Crud. Back to the hunt.
BTW, That list doesn't seem to be correct, at least in the 8CB listing. It says that that 'puter is from Bronco, F-x50 E-x50. This one came unmolested from a '90 2.3 Mustang.
Socal Tom
San Diego, CA
The ECU must be from a similar sized engine, that has the same mass air sensor and injectors that you are using. Short answer, get a 5.0 Mass air.
Tom
1sicbronconut
Come to think of it a 2.3L PCM might be the same as a truck because the newer 2.3L motors are dual plug. There are usually some of the PCM that you will need up on Ebay.
IPwizard
NE Ohio
If memory serves me right here the A9L was the most sought after EEC out of a Stang for the EFI Swap. I picked mine up form Ebay about 2 years ago for like $130 or something. I *used* to see them on Ebay all the time for $100-$150.
If I remember the A9L had the best code for proformance, and fuel maps, dont quote me on that though..
Mark
Mark
Bronco Klutz
NW Indiana
Yes. I have an A9P that I bought on a Mustang forum that is a faulty turd and has caused me to cuss many times tracing the problem. I was just at the junkyard this morning hoping to find something that would work and all they had was that 8CB. I was just hoping to get something today and not wait for shipping. There's many on ebay, I know.
I did a 5.0 swap on a Ranger. Ordered a reman computer from the parts store, special order. Dropped the old V6 computer in the core box. For something like $125 I got a reman computer with warranty that was correct for my application. As a note, the reman computers I have seen are fairly good. Apparently they know the problem parts and have upgradded stuff they put in so they don't come back.
Mark
Mark
Bronco Klutz
NW Indiana
The first place I called Friday evening was my Napa man at 5:50 pm - right when I knew my A9P was junk. He said it was special order and could take a few days. $144 plus core (which I have of course). I'm just anxious to fire it up! I'm thinking I'll call him back Monday AM and get it coming. What's a few more days. Plus it has a warranty to boot.
Recko555
Mark if you need to borrow one for a bit, I have one you can borrow. A9L. PM if you want to.
Mark
Mark
Bronco Klutz
NW Indiana
Thanks for the offer Gabe. But I'll be getting my refurb unit from Napa tomorrow at noon.
Cost $147 plus $117 core charge, but I'll be turning in the crappy A9P so I won't have to swallow the core charge. Plus I have a few other parts and a dizzy core to return, so it won't be a big hit.
I'd contact the guy I bought the crappy A9P from, he's from the Chicago area, found him on a Mustang forum, but I only paid him $90 and I'm getting $117 from Napa for it. Still kinda sucks but I'm anxious to put it behind me and hopefully I'll be all smiles tomorrow evening when I turn the key to "start". :) ;D :)
Dave
I also cheated on the core at NAPA. I ordered a manual tranny computer and tossed an auto in the box. I did that with the starter also. I'm bad%)
bigmuddy
Marthasville Missouri
Mark, please repost after you get your new ECM. Last time I looked for a reman'd unit, they said a few days but when we got to checking on them, there wasn't any at all in stock so they wouldn't give me a time line.
Seems like there have been quite a few that have been blown up by the addition of chips and because of people not giving the right core.
Ben
rtreads
I need a computer for a 5.8L. I have a C-4. Do I have to get a computer from an auto? If so all that I am finding in the 1991 era (the hear everything else came from) are the E4OD computers. I have heard to stay away from E4OD because they look for the shift point in the tranny and my c4 will not send that info to the computer. I have found a computer part number E9TF-AEB. Is this one ok?
thanks a ton!!
Recko555
thanks a ton!!
Start a new thread.
Mark
Mark
Bronco Klutz
NW Indiana
Ben
Sorry Ben,
Almost forgot. Everything seems ok with the Napa unit. I haven't been able to run it much (up and down my road) because of other electrical problems. But I got the ECU with no problems.
bigmuddy
thanks for the update Mark! I would still like to find a good extra computer to stick in the rig as a backup, but there are other things on the front burner right now.'
Ben
