EFI 3/8 id quick connect
Labbster
Anyone know where to get this that will connect to a 3/8 hose? I ordered this from jegs because it said it was for 3/8. It's not! Same as the stock 5/16. I am currently using a reducer just to get the fuel
garberz
Bronco Influencer
Conejo Valley, Ca.
3/8" hose? Stock is 1/4". The EFI fuel filter is 1/4". I'm running a stock Explorer EFI 5.0 with 5/16" steel line from the in tank pump, 1/4" hose from the steel line to the fuel rail. 5/16" hose should be more than plenty.
hankjr
rock auto has them for the stock exploder applications
Hank
pcf_mark
Any parts store can get the full Dorman line and they have it. I used their parts on my truck for what I did not grab at the yard. I clipped the fuel rail lines from the rails and used a razor blade to trim off the old line then put a fresh line.
Labbster
Labbster
I showed auto parts place the part above and they had no solution for me
chuzie
Am I being a bit overzealous using 2 EFI hose clamps rather than one on the pressure side?
