I have a 69 bronco with the 351 Windsor swap. My radiator lower outlet is on the passenger side. I have seen many frankenstien setups but I would like to know if there is a hose that fits the application in one peice. Does anyone have a hose # to try?
I have a 70 Bronco with a 351W and having the lower radiator outlet on the passenger side is most convenient, since my standard rotation waterpump inlet is on the passenger side.
So, I'm guessing the missing information is: You installed some serpentine belt system that required a reverse rotation pump, and the inlet is on the driver's side. I don't think the solution to add a length of metal tubing between the hose ends should be considered a frankenstein. It does work very well.
Also, member Pedestrian said he found a SuperDuty hose that fits pretty well. Try the search.
