Absolutely. Keep spark plug firing order the same as the cam.
Computer doesn't care or even know anything about the ignition firing order. It only controls the injector firing order. You'll have 4 of 8 injectors firing at a less efficient time in the valve cycle but it will run fine. Ford made millions of motors that fired all the injectors at the same time and they work ok.
The fuel mist will hang in the intake port until the intake valve opens. Not really much different than fuel delivery from a carb. I don't think you'll even notice any roughness.
You can rearrange the injector discharge in order to meet you cam firing order by swapping the pins in the ecu. There is some talk that this can cause 02 sensors to improperly read the exhaust, and I'm not sure which route is better.
You cannot fix it by just swapping injector firing order. That will cause problems with the O2 sensors. There is a way of changing the injector order and the cylinder number configuration to make the O2 sensors happy but it just isn't worth the effort. There's a thread on here somewhere. You'll end up with an engine with a strange cylinder number configuration that will cause confusion to everyone that works on it until it is dead. Either run it as is, change the cam, or re-program the ECM. Chances are you'll never be able to tell the difference.
