70EB
Background. 351W SEFI conversion using GT-40 lower and Cobra upper. I am putting together my lower intake before I mount it on the engine.
If I have the manifold in front of me there is a port near the Thermostat that is used to feed the heater. On the right side of the manifold in the port for the temp guage sender and the Air Temp Sensor.
Where do I place the ECT? The instruction sheet for the Ryan EFI Harness shows the connection on the pass side of the intake. (looking at website instructions as I do not have the harness yet)
The only other ports for coolant that are on the intake is on both sides in the rear that I was going to plug (instead of the rear cooling trick).
Which way do I go? i also do not have the coolant tubes that are found on the 5.0 EFI engines (thought about going this route to clean things up a little)
Bill
Bill
