Need some input from the experts. A lot of back and forth opinions on this matter and need some accurate information.
I have a 70's era carb'd 302 that I'm converting over to 5.0 HO Mustang EFI setup. Which firing order do I use?
The 302 firing order is 15426378. This matches my cam but if I wire up the mustang TFI distributor in this fashion, then the PCM injector and timing will be off. Meaning when the PCM tries to fire what it thinks is cylinder 3, cylinder 5 will fire instead. Wouldn't this cause misfires as combustion is occurring at undesirable piston stroke position? Granted the piston stroke and valves would all match with the 302 cam.
If I use the HO 5.0L firing order 13726548, the PCM would be happy but risk combusting cylinders early/late with the cam not in the correct position. Which theoretically is the same issue as above...
How do folks get around this when doing this conversion? For what it's worth I'm also doing the Explorer Serp swap as part of my EFI conversion so I will have the entire front of the motor torn apart should a (unplanned!) cam swap be required.
