EFI flooding sometimes on startup...randomly
b4opec
Sausalito, CA Marin
Hey guys- I converted to EFI sometime ago with no problems, but recently rebuilt and upgraded my intake. GT40, TB, MAF and 24lb injectors and A9L. Runs beautifully, I've logged about 700 miles on the setup. Every 10 or so times I shut the motor down, when I go to restart it will fire and then die. Then, it's completely flooded and will turn over but not a sign of firing. If I walk away overnight, and try the next day, it fires right up. The only way I can get it to refire soon after flooding is to pull all the plugs, ground the pumps and turn it over to flush it, put the plugs back in, and it fires back up again.
As you can imagine, this is a really unfortunate problem to have if you should pull up to get some groceries, walk out to the truck to go home, and suddenly you're spinning wrenches. I was hoping that as I put more time on the motor to let the computer learn, it would go away, but after 700 miles I'm growing concerned that it's something else. I have that nervous feeling everytime I turn the key now.
The TB is a performance products pos, which whistles horrendously. I had to crank in the throttle stop a little more than I'd like to get it to idle well, so I'm thinking maybe the computer is confused as to why the throttle is opened up so much at idle when you first go to start, maybe injects just a little too much fuel in? I'm also wondering if with its adjustable TPS that could have something to do with it? It's set at the base config for now and I'm not really clear on why you'd want to play with the TPS anyway.
Any thoughts you guys have are greatly appreciated. I always enjoy reading insightful responses.
kps74 bronco
south jersey,medford
It sounds like you know what you are doing,Was the maf calibrated to the 24lb injectors.I know the bbk throttle bodys tend to whisel,you can drill a small hole in the butterfly like the stock unit and that will kill the whisle,it did on mine.What codes are you pulling ?what type of fuel pressure are you at.and is the tps at .98 or so.Let use know ,I expect others will get see this and get it figured out.K
b4opec
b4opec
Sausalito, CA Marin
thanks for the post. I just read some stuff on corral.net, and feel a bit like dolt for not setting my TPS for starters. I'm going to do that in a minute. I'm also going to replace my air temp sensor and coolant sensor, with the thought process being the computer thinks the engine's cold at startup everytime. It's a cheap enough fix to give a try. The maf is calibrated to the injectors. I also might try drilling a hole in my butterfly--it couldn't hurt--I'm about a step away from just throwing that crap in the trash and getting something that doesn't whistle. Mine sounds so bad it couldn't be construed as something hot under the hood--a blower for example. It just sounds like hell and annoys the crap out of me
SaddleUp
Vancouver, WA
Check the fuel pressure. Especially look for a leak down after it is shut down that could indicate leaking injectors.
Also check your salt and pepper connectors and look for wear on the wiring where it may be rubbing the hood. I have actually seen that before. It was bad enough that they pulled the haunted engine and put a new engine with a carb in there.
b4opec
b4opec
Sausalito, CA Marin
Saddleup, your post didn't really resonate with me when I posted this thread over a year ago. It does now. I've had the truck parked for the past year or so, cause I more or less lost interest with the flooding problem I've had. Since I've been able to sit here and contemplate, from time to time, what the problem could be, it could only be that I have leaky injectors (I bought them used so who knows what state they're in). After your post I did put a fuel pressure guage on the regulator and they do lose almost all pressure after shutdown, some of the time. ..it just didn't make sense to me at the time what that could mean.
Clearly, I've got one (or more) leaky injectors that just sort of drip fuel into the heads after shutdown. Whether or not I lucked out and the injector was out of phase or the valve was open or closed at the moment of shutdown must be the reason I was flooding from time to time.
The truck's all wrapped up for winter but I'm terribly tempted to pull it out of hibernation and stick some new injectors in there. I have this strong hunch that's been the problem all along. I'll keep you all posted.
As always, thanks for your help
bigmuddy
Marthasville Missouri
b4opec, I had good luck with a company off of e-bay that rebuilt my injectors. I beleive it was Witchhunterperformance? They also flow test each injector with respect to the other injector and they will show the optimum min and max flow so you know you are good to go.
Ben
b4opec
b4opec
Sausalito, CA Marin
Bigmuddy, thanks for the heads up--I just checked out their website. At $17 per injector, that seems like a no-brainer. I suppose I'll also get confirmation if indeed I have a leaky injector.
$136 for peace of mind plus like-new injectors versus $300 for new injectors on a hunch...done
eds66bronco
Essex, Vermont
Ben
i used the same place for my injectors. really nice guy and way cheaper than all new injectors. i had only 4 injectors working and the other 4 were way below spec. all injectors came back within factory spec.
b4opec
b4opec
Sausalito, CA Marin
Hey guys- it's been a year of sitting and I just spent some time screwing around with the bronc and finally solved this issue.
I did rebuild the injectors--didn't solve it. I studied the fuel pressure--seemed fine, though I will add that my fuel pressure doesn't maintain pressure long after shutdown--it bleeds back down within minutes; the return line doesn't have a check valve or anything just goes straight back to the tank.
I went on to replace the TFI--didn't solve it. This was all last winter. I packed it and left her in the garage--lost interest entirely. At this point the only thing I hadn't changed was the dizzy itself, and reading corral.net and other sites it seems like I was experiencing a heat issue that would knock out either the TFI or the stator assembly in the dizzy. Pulling the plugs on the notion it was flooding was just giving the engine time to cool down enough to get the stator/tfi back online. I got a reman'd dizzy at napa for $120, bolted it up, fired within seconds. Havent had the problem since.
Now I actually get to drive this thing? And make it home? Wow, what a concept.
I also dumped the crap throttle body and stuck an edelbrock/bbk tb on there--whistle is gone. Very nice driving now
Thanks for all the input, even though I've been lazy as all hell dealing with this, all your input certainly did help me to iron out the potential issues at hand.
