pcf_mark
- Jun 11, 2010
- 3,594
Short story to give you all the details as they may inter-relate:
1995 5.0 stock EFI controlled by Megasquirt
New frame mounted pump from an 88-90 F250
Sealed cap - I know this because on a hot day the fuel expands and the air rushes in when I go to fill it
Return line is plumbed into the filler neck
The regulator is about two years old bought it new.
Cold start and driveability are awesome no complaints.
Two symptons I need some advice on:
When I shut the truck off the fuel pressure drops to zero very quickly. If it sits hot for 20 minutes or so it runs very poorly for a few minutes until it stabilizes. During this rough running period it smells very rich. I thought this was the fuel pressure dropping and the fuel in the rails boiling and pushing the fuel out the return line and the engine trying to run on a fuel / air coming out of the injectors. I can't pinch my return line as a test because all my lines are oem plastic. Should I replace my regulator since the fuel pump (and internal check valve) are new or could I have a leaky injectors?
When it sits in a small garage over night the fuel smell is noticeable. With a sealed EFI fuel system how can this be?
Are these two things related and can I test for something?
Maybe I have a leaky injector or injector seal that is causing the fuel pressure to drop, fuel is boiling and fuel is getting dumped into a cylinder when sitting?
