luderchris
New EFI setup. Started up after install. Checked the codes with a light and from what I recall, all of the codes were "normal" for the EFI conversion.
From the beginning, the truck would not idle when cold, but idled pretty good after nursing the throttle for a couple minutes. This was at every start up. It also would run fairly well under 3000 RPMs, but over that would break up badly and fall on its face. Almost like a rev limiter.
So, with 2 spare ECUs, I switched out the ECU and it performed the same over 3000 RPMs. The engine was already warm, so I didn't know if it made any difference on cold start up. I waited until the next morning and started the Bronco with the 2nd ECU, and it didn't immediately stall, it was a bit better, but did stall after 8-10 seconds. I go to start it back up and it will not start now! It is cranking strong, but will not fire. I changed out the ECU to the original, and still the same. It will crank over and over but will not fire. I even tried the third ECU and still the same. I also put three more gallons of gas in the tank to be sure it had enough.
Fast forward a week, and I now have a Harbor Freight fuel injection pump tester and a Ford code reader. Because of where the upper intake sits over the fuel rail, I cannot get the fuel pressure gauge hooked up. So I have not yet tested the fuel pressure at the Schrader valve. It does have pressure, but I'm not sure how much.
I just ran the ECU codes and I'm getting the following codes – 31, 81, 82, 85, 84
I ran them a second time and a 10 popped in there. I didn't know what that was until I looked at the manual closer and it showed that is a code for the cylinder balance test.
I appreciate any insights and help with this, I would love to get this truck on the road and back on the trails sooner than later.
Thanks in advance for your help guys.
Chris
Chris
