sp71eb
Well as the title says I am having some odd efi problems. I only have 25 miles on the truck so far. I have done a few KOER KOEO test and the only codes that are not emission related are 12 13 Koer. I am getting 85 44 33 but these are emission codes as far as I understand. I had the truck idling nicely and running relatively well, but under hard acceleration it pops and backfires with a loss of power. Its very odd that the truck runs great until the throttle is mashed, it will come up to full throttle and run great if it isn't mashed. I have...
rechecked timing
The coil, map sensor, act, ect, o2 sensors, plugs and wires are all new.
I replaced the iac and tps with no change.
I unhooked the maf while the engine was running and it wants to die.
When I first installed the iac the engine would die when unhooked but not it will stay running as long as it was unhooked after the engine was started. It seems like the iac is working but not keeping up and controlling well.
I have checked and rechecked for vacuum leaks and replaced all of the crappy rubber caps.
I tried to use the idle screw to lower the idle slightly but have caused the engine to lope badly so I had to screw it back in.
I checked the voltage of the tps and it is at .98 but one odd thing is that if I move the throttle it will go up to around 1.6 and then show open past around 3/4 throttle. This happens with both the new and old tps. This is very odd to me.
I also unhooked the o2 sensor harness and seemed to notice no difference other than a slightly higher idle.
Open to any suggestions or past experiences.
rechecked timing
