YellowBronc
Bronco God
- Jan 6, 2002
- 1,830
Q#2 : The tps probably needs adjusted , which you probably have done by now using the link posted earlier.
No sir I haven't got to it...ugh the wife had other plans...ok tommorrow...that's my first order of business when I get off.....I got it as a favorite....OK thanks....its running even better than before...I should have left the idle screw alone..that was my carb personality coming out....
How about the whirring sound coming from intake...if you look at my setup do you believe this to be normal?
Haven't been on here for a while because of sickness. Glad to hear you got it going. It's a good feeling, isn't it? Anyway, I to have the 302 firing order with HO injector order. Don't let the rough idle fool ya. It's the computer learning how to run again. The bad part of this mod is that if you disconnect the battery, the computer usually has to relearn again. It's much quicker the second time it seems to me though. Get a few warmups/cool-downs under it's belt. It will continue to run better every day. It just takes time.
As far as the whirring sound you're talking about.........funny thing is I notice the same sound on mine once in a while. I've really never figured out exactly what the noise is or where it's coming form. I've always assumed it's the sound of the injectors???? As you, I'm use to carb sounds. ;D
TPS.......check the voltage and adjust. Not the screw that adjusts the throttle plate. I didn't check the link JW0747 gave but will probably give directions on what I'm describing.
Hope it turns out for ya.
