EFI radiator help
Broncoglass
Morris, CT
I am wondering what you guys with reverse rotation water pumps are using for a radiator? I found several to fit but the hoses are on the wrong sides.
suckerpunched
some guys here, including me are using an early 90's explorer V6 radiator. V8 radiator wont fit. Others say it cools fine, but I don't have mine running yet. I think mine came out of a 94.
Either cross-over tubing setups, or a radiator specially made for an EB, but with the reversed inlets and outlets (like this one http://www.wildhorses4x4.com/product/Ron_Davis_Aluminum_No_Trans_Cooler ), or the Explorer radiator that suckerpunched mentioned.
Some good install threads on those hereabouts.
Obviously, the hose tricks are usually the simplest and least expensive. The dedicated RD radiator is virtually a simple drop-in, but at the same time is the most expensive option. The Explorer rad does require some trickery/fabbery on your part, but is a reasonable cost solution and, so far, a very good cooling option as well.
ransil
I'm using the explorer radiator, just came back from Moab and it kept the bronco cool, 2 other broncos I was with had over heating problems, temps were 95 plus each day.
1994 is correct need to make mounts, bottom uses a donut and you need to get them either at the junk yard or parts store, The radiators are cheap too.
OKLA70
Skiatook, Ok
My rad was fairly new when I swapped to the 5.0 so I kept it. I got an upper to fit (had to make a bracket to hold it up off the p/s pulley) and fabbed a lower with a couple different hoses. I used 3" long pipe and clamps to splice them. It's not the prettiest, but its on the bottom and the temp stays around 175/180
Tim
