bannind
- Mar 24, 2005
- 612
So I have narrowed down the winter projects and EFI is high on the list. As I think about the costs, I was wondering if the following plan was out of line.
We have fairly reasonable pick-n-pull's in my area. I was going to grab the upper/lower intake and EFI parts from a 96/7 explorer and all the associated parts attached to them. Then grab a harness from an early 90's MAF 5.0 with computer and distributor. I would save the Explorer coil packs, harness and computer for when I can justify a 4r70w swap. modify the other harness as needed and do the install. The reason for not using all the explorer parts, is it saves me PCM reflash and the Explorer harness rework. Even though the costs for Explorer PCM and harness are reasonable, the ability to save $500+ bucks on those parts alone makes the swap easier to justify with my wife. If I understand everything correctly I won't have to reflash early 90's MAF computer.
I have already gathered the parts and pieces for the explorer serpentine swap, so that is covered.
Thoughts?
Thoughts?
