SaddleUp
Huh? %) %) %)Miley said:BTW... those codes lie! Or at least they stretch the truth. I had too much resistance in my factory harness ground wire for the HEGO and the computer swore I had 2 bad O2 sensors, a bad MAF, and too low fuel pressure.
The codes lead you to a specific circuit that tests bad. They don't specify that a particular component "is" bad. The book I use always lists a number of possible problems with any particular code. It might list a bad sensor as a possible cause of a code with further instructions elsewhere for testing the sensor itself and the wiring circuit leading up to it to verify whether it is good or bad. (When listing the tools above I missed a good EFI book which I also have found to be invaluable) As for a code saying the fuel pressure is low there isn't a single code that the ecm gives that would say this. %) The ECM doesn't even check fuel pressure. (Hence the requirement for a fuel pressure guage when diagnosing problems)
As far as burning up fuel pumps the only thing I can think of that would cause that many of them to go out would be either from feeding garbage through them or using a really cheap low quality pump. (My brother went through 2 pumps on one of his vehicles before he pulled the tank out and cleaned it and he hasn't had a problem since) The EFI system itself would not cause a fuel pump to fail since it doesn't really control it. If a mechanical pump was capable of pumping out enough pressure the EFI system would accept it as a subsititute even though it would report a failure from the FP Monitor circuit. It wouldn't even throw the ECM into limp mode.
