Yep. 87 SD for an Auto out of a Mustang. Or at least that's what the code (DE) shows up on Ryan's site as. The year comes from the Ford part number.
Not sure on the question so I'm going to guess. I assume you are wondering whether to run it or change it. That requires more questions though. For a stock motor with very little change the SD system is just fine. Once you start making changes to the motor (Especially things like a different cam) then either the SD system needs to be tuned using a chip (If it has a port for one which is doubtful in 87) or you need to switch to the MAF system. The difference is that the MAF system is better at coping with the changes and will learn a new program for them.
Actually I would go ahead and run that one for now. Swapping to the MAF one down the road isn't very complicated. The swap only takes a couple of hours and most of that is figuring out how to mount the MAF unit.
