Bought a HF 1100 lb hoist, on sale with a 25% off coupon. Attached it to 1.5 inch box steel 10 ft long and that to a 10 ft long 4X4 run perpendicular across reinforced rafters. It all sits up in the attic of the garage. Then I installed another access panel below it. I used it to lift the top off, the entire body off the frame, and to hoist the body dolly up to the ceiling to keep it out of the way when not using it. It plugs into the garage door opener outlet and the controls hang down through the access panel when I'm using it. When I'm not, it's all tucked away and whatever I've lifted is attached to eye-bolts with chain or HF ratchet straps. Sorry, it's AZ and 110 outside. Not willing to crawl up there at the moment to take a picture of it.
