Steve, I appreciate your help, but I am at a loss.
My electric fuel pump runs as you described in your diagram. I actually followed your diagram when I wired the Carter Electric Pump after installing the Sherman tank.
I just want to know what wire goes from the stock OEM Fuel Quantity Gauge to the Fuel Selector Switch. I am not seeing any other wires other than the Yellow w/white Aux Tank Sender Wire & the Orange wire with 90 degree Boot on that is connected to the Fuel Quantity Gauge.
IF anyone can dumb it down a few levels for me, greatly appreciated.
Otherwise, I'll put a jumper from the fuel quantity gauge to the center terminal of the fuel quantity switch.
EDIT: I found another diagram. I believe my issue is, disregard the Orange 286A that has the 90 degree boot that connects to the fuel gauge, since that terminates at the rear/main fuel tank and is reading nothing, since a new orange wire was run from the new fuel tank to the fuel switch.
So I guess, disconnect 286A at the gauge, and run a dedicated jumper from Fuel Gauge to Fuel Select Switch. Will update if this solves the problem. I cannot see it being any other way.
Directions are a bit misleading since it says use OEM wire to gauge for the center top terminal of the Fuel Selector Switch. We shall see.
