Electrical harness question
nickeboy
I was looking at doing a new Harness in my Bronco. I'm trying to decide between Painless, Centech and West Coast Broncos. I have seen other threads on similar topics, but I have some questions.
I am leaning towards WCB harness cause its price and mods. I know that you have to use original connectors if doing this. Most of my Bronco is modifies and somewhat primitive. The only thing I can think of that will need original connectors would be the headlights, tail lights and blinkers. I'm pretty sure everything else is aftermarket (gauges, stereo, wipers, msd)
Anything I'm missing?
what do you think?
BluebroncoNC
Asheville, NC
what do you think?
Well, yea. The connection to the resevoir for the Wiper Sprayer is different. I had to use the connectors for the Steering Column, actually had to add a pin for the lighted transmission indicator on my column into the connector pin from Painless. Thore are two off the top of my head, there still may be ignition harness connectors you may need to utilize, but i'm not certain. Good luck.
Pa PITT
Stephenville TEXAS
I'd say go with the cheap one in your situation .. Northern or E-Z wire is only about 150 bucks .. Plugs for the head lamps can be bought at Napa or O'Riley in Pico oe BFE brand.. Tail lamps are common also .. Blinkers either wire in your old one or ask also at napa .. ..
... Bigger problem in my opinion is the Ign switch.. Mine came with a Briggs & Stration ign switch .. I wasn't to proud of this .. But since I was doing such a swap I just stayed hooked with it.And save about 400 buck.
nickeboy
nickeboy
Thanks Pappitt. Anyone else have some advice. I think I'm gonna pull the trigger on the wcb. How many circuits?
Dusty
I'll give it my endorsement. I was the one who worked with Northwest Autowire to develop the WCB-specific variant of that harness back when I was a partner at WCB.
