Bronco919
Hi everyone,
Finally got the Bronco running again after 2 years. (WOO!!!) But here's the problem list:
When I rev the engine, the volt meter also increases to around 18 volts. Is my regulator shot?
And I moved the old regulator over on the firewall to make room for the duraspark ignition module and the cigar shaped ground wire broke off. (Could be the reason for above?) Do I need this or can I just ground it without the cigar shaped thingy?
Oh and I used to post here several years ago when the bronco was running, but I've forgotten my username.
Sam
Houston, Texas
Sam
Houston, Texas
