HigginsHorse
- Sep 10, 2003
- 530
Last time I tried to start my bronco, the ignition switch got hung up and would not stop. I had to disconnect the battery to get it to stop. I have replaced the ignition switch. I tried to hook up the battery today but got a shock instead. I don't know if this matters or not, but I hooked up the positive side first and then when I went to hook up the Negative side I got a pretty good arch on the battery.(enough to disfigure the post a little). I didn't cross the wires to the battery, double-checked that before I tried to connect it. The starter didn't turnover so I don't think the starter is hung up (I could be wrong). Did I cross some wires when connecting the ignition switch. If I remember correctly the plug that connects to the ignition switch only fits one way so I don't think that is it. The key was not on or even in the ignition.
Any suggestions.
HigginsHorse
Any suggestions.
HigginsHorse
