- Dec 18, 2003
- 5,045
So, we've done two things to the electrical since the bronco last ran without issue.
1. We added the explorer serp setup with 4g alternator. Red/Green wire from the voltage regulator to the alternator red/green, charge lug to positive battery side of the starting solenoid.
2. Installed a grant steering wheel.
The first thing that told me something was wrong, when we hooked up the battery, the horn was stuck on. I'm guessing it has to do with my grant steering wheel install.
The second thing I noticed tonight. With the engine running, when I turn the wheel ~20 degrees off center, I can see sparks between the shift collar and steering wheel. In addition, the whole electrical system seems to short out when I get the sparks. Radio shuts off, lights shut off, but the ignition is still powered. The radio is powered off a relay that is signaled from the I terminal of the starting solenoid.
Oh, and the short apparently also prevented the key from activating the starter. I'm guessing the horn is shorting the I terminal to ground, effectively shutting down all of the electrical items. Does this even make sense? It doesn't do anything in ACC or ON, only with the engine running.
