Even though the two issues might be unrelated, the bad ground thing might indicate that it's a bad battery cable on the negative side.
Would not be the first time someone encountered a bad cable even if they look good, or even new.
For that "new" part, the only time it happened to me personally the positive battery cable was less than three years old and looked brand new. Failed internally and all power would die as soon as I'd turn the key to START. Everything worked fine up to that point, but after that literally everything was dead.
If truly everything is dead, then there are only three (ok four) things that can cause this:
1. Bad positive battery cable.
2. Bad negative battery cable.
3. Blown or just a failing fusible link (it's at the end of the Black wire on the battery side of the starter relay/solenoid, powers the entire truck and charges the battery.
4. The main connector behind the ammeter in the instrument cluster. If it's rusty, loose or partially disconnected it can kill power to literally 99% of the truck.
Good luck.
