I have read a few threads and hope I haven’t wasted money on an eBay NOS signal switch.
Sooo I foolishly hooked a stereo amp to the lighter as a power source , it’s been hooked up a couple of years and hasn’t been an issue until I put a larger fuse than 14 amp in the fuse box , I know!
Well the wires on the hazard switch fried , I pulled the steering wheel and it obviously got melted. So I found a NOS switch and bought it.
while waiting for it I removed the amp from the lighter and ran direct to wire with fuse , all wiring now is stock.
New switch came looked good and like new . Installed switch now
- hazards work
- all lights work
- items on 14 amp fuse work windshield washers etc
Blinkers do not work , have installed a new flasher module also tried using hazard flasher with no change, there is power at the flasher module it lights my test light bright on orange wire and dull on the other side?
I have jumped across the 2 and nothing.
With brakes on if I switch from side to side the brake light goes out?
Sorry for the long question.
Any thoughts would be appreciated thanks
- hazards work
- all lights work
