So I have the H4 headlight conversion and recently at night I got on the skiney hard from a stop light and I noticed a flash. Which at first I thought was one of those dang traffic light cameras. I then noticed I blew out a headlight. After I stopped and took off again the other headlight went out leaving me in the dark with only running lights. I popped on my brights and they came on only to also blow out a few block from home.
So I figured a new voltage Regulator would do the trick. Put a new one in and all was good and my amp meter was reading good. That was a few weeks ago.
So tonight I went out for drive and popped one headlight again and my amp meter was bouncing all over the place. So I pulled the alternator and took it to Napa. They tested it and all checked out to be good. I then swung by Kragens and had them test is as well just to be sure and it tested fine again.
So before I go buy another Voltage regulator is there something else that could be causing this that I should be looking for.
Any help and suggestions would be greatly appreciated.
