electronic fuel switch
sweeneycam
slidell
can I use my gauge selector switch as a all in one switch for electronic fuel selection? If so how do i wire it? Thanks
By all-in-one, do you mean just for switching the gauge AND the valve? If so, then sure. I did it on mine when I swapped the old one out for a 6-port (for return lines) valve years ago.
I haven't used it with EFI yet, but will be doing just that in a short while. I don't think it'll have any trouble with the 40+/- psi of the EFI pumps.
As to how to wire it, I think Viperwolf has a diagram in one of his galleries, so you might want to check out there first. It's pretty straightforward, but I couldn't just rattle it off from memory at this time.
Maybe someone else who's done it more recently will pipe up with a better answer.
oleguy74
calif city ca
fuel sw.
this is what you need.
