electronic ignition diagram needed
Pearland, Houston
Hi all,
I need a wiring diagram for a GP MAGNA SONIC ELECTRONIC ignition module. The current wiring situation is rather sketchy and I believe is causing my battery to short. Couldn't find anything on the google. Any help is always greatly appreciated.
Tyler
broncnaz
Might need to try and post some pics of what you have. Also some other info would be helpful like year of your bronco and info on the distributor.
I had heard of GP magna sonic before. Dont have any real solid info on them but I do believe that they were part of Standard Motor products at one time so some parts may just be marked magna sonic and just standard parts nothing specail. On the other hand they also made conversion igintions so you may want to check inside your distributor to see whats in there. If its truely causing issues then it may be time to swap it out for something more common.
I kinda doubt that the igintion is causing your battery issues. Usaully if the ignition is drawing power all the time you wouldnt be able to shut down the engine.
