Don't have pics, but you should be able to mount it pretty easily, maybe with just a bit of mods to the pedal.
The most common is to leave it attached at the firewall, but remove the bolt under the dash, push the assembly over until it clears, and then drill and bolt it in it's newer position.
You might even find that moving the pedal allows you to do the install then putting it back to it's original, or at least closer to original position, will work too.
Which pods are you using?
