bmblauvelt
I have a 1977 Bronco Ranger with a modified 302 V8. To combat cooling issues with the overheating issues, I have done the following:
- installed an aluminum racing radiator, and removed the transmission lines from the radiator cooling load
- added a seperate transmission tube and fin type oil cooler welded on to the frame below the engine (I have done serious off roading, and the only damage came when I totaled a Pontiac GrandAm when I rear ended it - oops)
- added a copper marine transmission cooler inline with my tube and fin cooler
- added an electric fan in front of the a/c condenser (this required changing the hood latch mechanism from stock to hood pins to buy the needed room up front)
- had the hood louvered - I think it is 8 on each side of the stock hood "bubble"
- changed to a high efficiency engine fan
So, with all this, I have had some improvement, but the tranmission still runs hotter than the recommended 175F maximum. When I am trailering my boat, or in hot weather without the boat in stop and go traffic with the auxilliary fan running the transmission still runs at over 250F. I already had to have my tranmission rebuilt once (and had it beefed up at the same time), for some serious $$$, and I like to prevent having to do that again. I understand that heat is the tranmissions biggest enemy, so I am looking at other ways to reduce the heat build up in it.
Any thoughts?
Brian
Any thoughts?
Brian
